rattling fretboard?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=27129
Author:  Heath Blair [ Fri Apr 23, 2010 12:27 pm ]
Post subject:  rattling fretboard?
i just finished binding a fretboard and now when i tap on it, it rattles. anyone else experience this? the binding joints all look tight and ive cleaned the slots out. no frets obviously. any help? thanks in advance.
Author:  Pat Foster [ Fri Apr 23, 2010 1:01 pm ]
Post subject:  Re: rattling fretboard?
Most likely the truss rod, if you're using one. Try tightening it just a touch and see if that changes anything.
Author:  Heath Blair [ Fri Apr 23, 2010 1:37 pm ]
i just radiused the board and the rattle went away. maybe just some glue or something that got planed/sanded away. either way, no more rattle. idunno
thanks for the tip anyway, pat.
sorry for wasting forum space with nonsense.
Author:  JohnAbercrombie [ Fri Apr 23, 2010 1:44 pm ]
'Things that go bump in the night....and then go away'
It's happened to everybody- no worries.
Author:  Heath Blair [ Fri Apr 23, 2010 6:28 pm ]
what in the world?! its totally back. i must be going crazy.
Author:  Heath Blair [ Fri Apr 23, 2010 6:45 pm ]
just to be clear, this is an unfretted board that is NOT attached to the neck.
Author:  John How [ Fri Apr 23, 2010 6:50 pm ]
Maybe it's cracked somewhere?
Author:  MRS [ Fri Apr 23, 2010 11:43 pm ]
I was just going to suggest what John suggested. So I'll suggest loose inlay maybe. But i still think john got it right....Mike
Author:  Bobc [ Sat Apr 24, 2010 5:11 pm ]
Heath wet it with some naptha or alcohol. That should make a crack stand out. Don't forget the edges.
Author:  Eric Reid [ Sun Apr 25, 2010 12:55 am ]
If it's the truss rod, there's a silicone you can inject that's an instant cure. It has no effect on the function of the rod, just stops the rattle.
Author:  Kim [ Sun Apr 25, 2010 1:39 am ]
It's not snake wood by any chance is it??
Sorry :roll:
Author:  Kim [ Sun Apr 25, 2010 2:10 am ]
That was not very helpful :|
If you hold it at the sweet spot up next to your ear and tap it and you get no real sustain and more of a rattle, I recon it's a safe bet to be a crack. If it hisses at ya, drop it and run away quick.
Author:  Alexandru Marian [ Sun Apr 25, 2010 3:12 am ]
Kim, this should make it to the luthiery jokes collection laughing6-hehe
Sorry Heath oops_sign
Author:  MRS [ Sun Apr 25, 2010 4:19 pm ]
Well the fingerboard is not attached to the neck yet but silicone is recommended prior to installing the truss rod. A small bead at the bottom of the slot before installing the truss rod. I recommend 100% silicone which doesn't harden like silicone caulk.
Author:  Heath Blair [ Sun Apr 25, 2010 10:32 pm ]
ha! thats pretty funny. no, its not snakewood. it is mad rose though, and that can get crack happy i suppose. i havent had a chance to fiddle around with it anymore, but it rings long and loud when i tap it. im thinking theres just got to be something hung up in one of the fret slots. ill wet it down with some mineral spirits when i get a chance. see what i can see. ill probably dig around in those fret slots some more too. thanks to all for the advice and ill get back to ya with the findings.
